Just like the title says. I am unloading one of my XJ D44's.
XJ Rear D44 welded, drum brakes (missing a drum but everything else is there) and has 4.88 gears installed. it's been sitting in the garage open without a diff. cover and has flash rust on everything. it could be run just fine after soaking in some penetrating oil and gear lube for a while and turned over a few times, or might need new bearings. It needs a pinion seal as well. I will through in a heavier Rubicon D44 cover in with the deal.
Please PM me if interested. I want this gone fast. I WILL TAKE LESS THEN THE NORMAL $400 people ask for the XJ D44 and this one has gears installed.
I will NOT hold this for anyone, first person with cash will take it.
