Old June 16th, 2010, 10:54
kmanxj5050 kmanxj5050 is offline
Ball joint q's???
Would these work in an 01? i know they are low pinion but the ball joints are different???
and if these will work anybody ever buy these?? way cheaper than the local parts stores???
Old June 16th, 2010, 10:58
yossarian19's Avatar
yossarian19 yossarian19 is offline
Re: Ball joint q's???
Check your post: are you missing some information there?
Otherwise you are asking if ball joints will work in an 01. They will.
Old June 16th, 2010, 15:35
ha lol forgot a link haha
these are the ones listed for cherokee. They only go up to 99
http://cgi.ebay.com/ebaymotors/4-Bal...fAccesso ries
Old June 16th, 2010, 16:53
Banditt007 Banditt007 is offline
As a side note i've noted MANY parts list things only up to the 1999 model year... even parts that you would think would fit all the model years. hmm
Old June 17th, 2010, 05:16
wanna order these today. but want alittle more input thanks
Old June 18th, 2010, 07:42
nobodys ran these huh?
Old June 18th, 2010, 08:55
89xj 89xj is offline
if they arnt spicer, i would not run them.
did a quick search for spicer ball joints on ebay and got this:
http://cgi.ebay.com/ebaymotors/Dana-...fAccesso ries
Old June 18th, 2010, 09:11
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
alljeep, crown, or rockauto can probably beat those prices... haven't checked to be honest but they usually do.
EDIT: the only way you can beat those prices is by not doing the job at all... they don't list a real brand name, or any brand name at all, which makes me think they're total junk.
Old June 18th, 2010, 11:31
those spicer are cheap!!! will probably go with those. thanks
Old June 18th, 2010, 12:31
hot_rod_hooligans's Avatar
hot_rod_hooligans hot_rod_hooligans is offline
These are cheeper, and they are Spicer
http://www.alljeep.com/oscommerce/pr...ucts_id=167752
Is this the ball joint I need? Mudshack OEM Tech Discussion 8 April 8th, 2010 08:54
BALL JOINT$ Jacobus OEM Tech Discussion 5 April 15th, 2008 00:02
HF Ball joint / U-joint tool half off deal... Ivan Non-Tech / Off Topic 7 May 25th, 2005 17:08
How do you tell if a ball joint is bad? Fletch85 Modified Tech Discussion 4 April 12th, 2004 21:44
Ball joint / axle - u joint replacement rail351 OEM Tech Discussion 7 September 21st, 2003 15:50
