Old January 12th, 2010, 16:37
1987Comanche 1987Comanche is offline
Dana 30 CAD to non-CAD?
Is it possible to remove the outer & inner axle shaft on the RH of the Dana 30 CAD (1990 4.0) and replace them with a 1 piece axle shaft from another Dana 30, say a Select-Trac equipped XJ with a non CAD Dana 30?
If this isn't possible are there any negative side effects to moving the slip ring to the engaged position permanantly (vibration, excessive wear, etc). I'm not really looking to do an entire axle swap at the moment but would like to make the 4WD work again.
Old January 12th, 2010, 16:43
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
Re: Dana 30 CAD to non-CAD?
It is possible. You install a blockoff plate on the actuator port and install a seal in the inner end of the axle tube next to the carrier. A search on here should find you the part number for the seal.
Old January 12th, 2010, 17:22
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
The easiest way for you right now.. is to just slide the fork over and keep it there. You can use nuts, washers, etc.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old January 12th, 2010, 17:24
I'll search for the seal. Is there a bearing in the axle tube that has to come out when doing the conversion? What's a good donor vehicle for the drop-in RH axle shaft? Any XJ-MJ D-30 without the CAD?
Old January 12th, 2010, 17:36
tbburg's Avatar
tbburg tbburg is offline
Any '96-up axle shaft. If you're pulling them at a yard, get both axles. The late mod. shafts have larger U-joints. It's a worthwhile upgrade.
If you want a simple fix, pull the actuator motor off the axle, move the fork into the engaged position, and shim it in place with washers. No detrimental wear issues that I've heard of. Should cause no vibration either.(Front DS turns even when disengaged because the left axle shaft is still driving it's side gear, and internal friction will turn the dif. carrier.)
Old January 13th, 2010, 16:37
'96 up is what I needed to know. I'll try sliding the ring over 1st and if there are issues I'll grab new axle shafts at the JY.
Old January 13th, 2010, 19:07
tbburg's Avatar
96 up is the short answer. If you're pulling them yourself, any model with the -242(full time) transfer case and ABS(look for the pump in the engine compartment, and the tone rings on the shafts) will have the bigger U-joints and 1-piece shafts.
And you will have to put an axle seal in that side.
Old January 14th, 2010, 05:54
ROKTOYXJ ROKTOYXJ is offline
My disconnect is acting up as well. I will be shimming mine this weekend. Still plenty capable in 1 wheel drive
Old February 28th, 2017, 01:29
93bluebeast's Avatar
93bluebeast 93bluebeast is offline
How difficult is it to break a stock shaft with 32 inch tires and maybe moderate trails? Would it be a waste to upgrade to the Chromoly shafts at that point?
Old February 28th, 2017, 04:16
VAhasnoWAVES VAhasnoWAVES is offline
wheeling moderate trails moderately... should be fine.
get the 30 bound up or get carried away with the skinny peddle and losing a shaft is definitely doable.
Dana 30 Diff Covers, 1997 Intake Manifold, Dana 30 Shafts Mdub Arizona For Sale/Wanted 9 May 19th, 2008 14:38
rebuilt xj driveshaft with yj slip, sways, 31's and 33's, dana 44 shafts, dana 30 blondejoncherokee Sierra Chapter For Sale 2 May 14th, 2008 13:35
Loaded Rear Dana 44, locked Dana 30, 31" BFG's, other stuff for sale JimsXJ For Sale: Private Party Only. XJ ITEMS ONLY 6 April 4th, 2008 18:57
will high steer knuckles for a cj dana 30 fit a reverse dana 30? bill hitchcock Modified Tech Discussion 3 April 26th, 2003 10:06
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
