Old November 2nd, 2009, 17:48
Hylander's Avatar
Hylander Hylander is offline
Leaking Thermostat Housing ?
I can't seem to get my TH to stop leaking.
It is leaking through the gasket.
I have replaced it twice, once just last night and today it is still seeping.
I tried Gasket with no RTV, then Gasket with RTV.
Leaks at the same spot each time.
I'm thinking the Housing is warped ?
Old November 2nd, 2009, 17:53
mattbred's Avatar
mattbred mattbred is offline
Re: Leaking Thermostat Housing ?
Positive its the housing and not a hose that goes to it?
Old November 2nd, 2009, 18:03
5-90's Avatar
5-90 5-90 is offline
Which spot, specifically, is it leaking from?
If it's coming from somewhere near the base, inspect the mating surface on the cylinder head (pay particular attention to the screw holes) and on the housing. If no defect is visible, get a flat bastard or mill file (or 120-grit sanding sheet stuck to a rigid flat surface) and clean up just enough to get it flat. I'd probably put a coat of machinist's blue dye on the thing before I started cleaning it up - it will show up any unevenness in the surface (as soon as you start sanding/filing) and tell you when to stop. You should only remove enough material to make the surface flat (it is unlikely that you have to do any cleanup work on the head casting.)
Again, pay attention to the screw holes in the housing - check for any cracks between them and the "main chamber" that could be passing water when hot or under pressure.
Make sure you haven't "corroded through" anywhere on the two hose nipples, which could give you a leak from under a hose. Also, you can get a "corrosion channel" on the outside surface that can do much the same thing. In either case, the repair is actually replacement.
Tell us the specific location of the leak on the housing, and you'll get more specific advice.
Old November 2nd, 2009, 18:05
wishbone's Avatar
wishbone wishbone is offline
just use RTV. I applied 1/4" RTV bead, finger tighten the bolts, but leave some room between the surfaces. I waited 24 hours, then went back and tightened them down, and no more leak.
Old November 2nd, 2009, 18:31
Hylander's Avatar
It is leaking just about 1/4" above the Lower Bolt and
extending up about 1.5" right through the gasket.
I'm thinking I should just order a new Housing, But will try the Flat File
to clean it up.
Old November 2nd, 2009, 18:45
joe_peters joe_peters is offline
to clean it up.
Wrap some sandpaper around a piece of 2x4 and hit the gasket surface--that will show you if you have high/low spots.
Getting the mating surfaces clean is a must--bare metal. Check around the bolt holes in the head with your finger and feel if the surface is raised. Use a regular scraper to clean the head of any left-over gasket/sealant.
I'm old school. I use Permatex non-hardening on the t/stat housing, with a couple dabs to anchor the t/stat in the housing, and I never put anything on the head mating surface. You don't want sealant on the head itself where it is so hard to clean up.
Old November 2nd, 2009, 19:18
ehall's Avatar
ehall ehall is offline
The housings are aluminum and warp over time. Luckily they are pretty cheap so if you've got some pocket money just replace it.
my '91 beater rebuild
Old November 2nd, 2009, 21:27
iwannadie's Avatar
iwannadie iwannadie is offline
I had the same problem a while back. For me the problem was a small amount of coolant in the head. With the housing off no coolant would drip out but with the housing in place a tiny bit would seep and ruin the gasket/rtv enough that it would then later leak really bad.
I took a fluid pump and got as much of the coolant from the head as possible, solved my problem.
Old November 2nd, 2009, 21:30
mattbred's Avatar
I noticed this when changing my tstat - I sucked some out and jacked the front of the engine up to make the coolant sit back. Problem solved! Need a dry surface.
Old November 3rd, 2009, 08:25
ChevelleSSLS6's Avatar
ChevelleSSLS6 ChevelleSSLS6 is offline
I cracked the Hesco unit I bought for my XJ earlier this summer, and with a little grinding and JB weld (ghetto I know) it works great now. DO NOT torque the tstat housing down very hard!!!
thermostat housing help!! CBB311 OEM Tech Discussion 10 January 22nd, 2009 22:18
WTB thermostat housing Israel InterMountain Chapter For Sale/Wanted 3 September 9th, 2008 05:51
thermostat housing 4.0L dude in an xj For Sale: Private Party Only. XJ ITEMS ONLY 0 May 30th, 2007 18:24
Fun with the thermostat housing BIGSLVRXJ OEM Tech Discussion 0 January 29th, 2006 19:51
Aftermarket Thermostat housing for 4.0 ? 96 Cherokee Modified Tech Discussion 9 November 11th, 2005 08:38
