Old April 8th, 2010, 19:46
Dundy's Avatar
Dundy Dundy is offline
Re: 241OR Rock-Trac/Teraflex 2-Low/Novak Cable Shifter Install
Originally Posted by pyrotyro View Post
see the problem isnt the speedo being off. the problem is there is no connection for me to even get a speedo reading at all... without redoing the tailshaft
i was talking in general, trying to see if someone has experience with it.
Old April 8th, 2010, 19:49
crasy1_69's Avatar
crasy1_69 crasy1_69 is offline
NAXJA Member # 1649
Ok with all the talk of speed sensors, does anyone have an answer on how to connect the 3 wire VSS connector on the tcase to the 2 wire connector on a 91 4.0/AW4?
Craig
Old April 8th, 2010, 20:22
pyrotyro's Avatar
pyrotyro pyrotyro is offline
Originally Posted by Seiler View Post
Hey Pyro, can you do me a favor and take a picture of the tag on your case? It should look something like this:
Try to get close enough so the lettering is legible.
Thanks,
Scott
what will you look at on the tag?
Old April 9th, 2010, 16:26
Seiler's Avatar
Seiler Seiler is offline
Craig
Not quite sure on this. Would you happen to have a FSM? If you could figure out what each of those two wires are, I imagine you could connect it somehow. What color are the two wires?
I mainly wanted it to for my database, and to make sure it was 4:1. Keep us updated on what you decide to do with your case. I'd like to know.
Scott
Previous Member Name - xj²
Old April 10th, 2010, 14:59
praetorian praetorian is offline
Has anyone held a 241 SYE tail housing up the the JK 241 tail housing to see if the bolts line up to see if that route might work. Also JB Conversions has NEW JK 241 4:1 RocTracs on sale for $1299!
Old April 10th, 2010, 16:37
METAL MONKEY's Avatar
METAL MONKEY METAL MONKEY is offline
SOB!!!! I must have a knack for picking up a good deal, and then finding a better one literally days after.
Old April 10th, 2010, 18:15
Seiler's Avatar
Wow I guess so. That is one hell of a sale. I wish I would have paid $600 less when I purchased mine. Sheezus.
Old April 10th, 2010, 19:15
Gascan340's Avatar
Gascan340 Gascan340 is offline
Not to high jack but does anyone have info on this type of swap in with a cable speedo.
Old April 12th, 2010, 00:30
pyrotyro's Avatar
then youd be in the same boat as me...
Old April 13th, 2010, 13:44
crasy1_69's Avatar
NAXJA Member # 1649
Scott
I don't have a FSM. The wires are black and white.
Craig
Old April 18th, 2010, 20:10
I swapped the 241OR in my XJ a couple weeks ago with Seiler's help. My speedo was reading about 15% fast like Seiler's. So, I ordered the dakota digital speed calibration box this week since it is the cheapest option, and installed it yesterday. Someone linked the SGI-5 dakota digital unit earlier in this thread, but here it is again.
http://www.dakotadigital.com/index.c...rod/prd126.htm
They're in SD, so it only took 2 days to get mine since I'm in CO. I did talk to one of their techs to make sure it would work, and he told me there shouldn't be any problems. So away we go. Installation is straight forward. Much like the Superlift TruSpeed.
- Splice into the speed sensor signal.
- From the tc to the interface input (didn't need to connect the speed
sensor gnd).
- From the interface output #1 to the ECU.
- Connect to a good ground.
- Find a switched 12V source in your fuse panel. I used #17 per the Superlift instructions using a single auxilary fuse holder from autozone.
My dipswitch settings are:
DS#1 - ON
DS#2 - OFF
DS#3 - ON
DS#4 - OFF
I calibrated mine while driving using a gps, so I didn't do the calculations (even though they are easy). A quick drive down the road, hitting the down buttons a few times, and I'm spot on again.
Old April 18th, 2010, 20:14
Craig
Put a meter on the 2-wire connector to find out what wire is what. You know for sure at least one of them is the signal. I'd be willing to guess the other is power. The black wire on the 241 is the speed sensor ground, so you should splice in a ground wire to connect to the chassis somewhere.
Old April 18th, 2010, 20:45
Seiler's Avatar
sensor gnd).
DS#1 - ON
DS#2 - OFF
DS#3 - ON
DS#4 - OFF
Good to hear Cam. I'm glad it all turned out OK.
Scott
Old April 18th, 2010, 21:05
crasy1_69's Avatar
NAXJA Member # 1649
Thanks for the info. I'll have to give it a try this week and get back to you.
Craig
Old June 7th, 2011, 19:46
StanBo StanBo is offline
I wanted to say thanks to all of you for all of the great information on this thread. I am in the process of figuring out what I want to do with my truck and this thread helped a great deal.
I was going to upgrade my current transfer case but feel the extra money is worth it to get the 4:1 ratio.
Seiler (as well as everyone else) thanks for the thread and all of the info!
Novak shifter and the 2-low kit xjtrailrider Modified Tech Discussion 4 March 31st, 2009 20:12
Novak T.C. shifter SUA SPONTE Modified Tech Discussion 14 January 23rd, 2008 20:15
Novak SHifter Q's Kejtar Modified Tech Discussion 20 May 8th, 2006 22:40
Novak shifter for the 231? Kejtar Modified Tech Discussion 9 March 5th, 2005 05:44
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
