SeansBlueXJ
- Plainfield Township, PA
Ok so here is what's going on, and what I have done so far. 2000 XJ overheats, sometimes to the point of redline. Heats up faster on the highway then side roads. So far I have changed all the typical cooling issue things and nothing has helped. I have done a fill/drain flush, new t-stat, new water pump. I first suspected an 0331 head crack as my mother's 00 did the same thing when the head went, but so far no crack, and no antifreeze in oil or vicea versa. The raditor fins are clear and clean and the fans both spin. It's getting to the point where I cant go anywhere. Is it a clogged raditor that didnt clear with my drain/fill? Any other ideas?
