Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 13th, 2017, 09:01
asymptonic asymptonic is offline
Another boring tick thread
I have lifter tick for sure, but after she heats up ('98 manual), there is still about a 6hz tick at idle. Listened to the engine with a stethoscope and it seems to be coming from the bell housing.
Thoughts?
Old September 13th, 2017, 22:49
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Another boring tick thread
Cracked flexplate?
It happens.
Take at look and make sure the flex platebolts are tight, while you are at it.
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old September 14th, 2017, 05:34
cruiser54's Avatar
cruiser54 cruiser54 is offline
Clarification. Manual trans?
Old September 14th, 2017, 06:31
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
How old is the clutch assembly?
Old September 14th, 2017, 11:27
Manual tranny. Clutch is maybe 4 years old.
Old September 15th, 2017, 10:42
I should add the noise happens with the clutch in or out.
Eliminating the "tick, tick, tick" ParadiseXJ OEM Tech Discussion 69 June 9th, 2011 08:58
Another boring MPG thread blistovmhz OEM Tech Discussion 4 April 18th, 2011 23:11
Tick, Tick, waiting for BOOM PoopJeep OEM Tech Discussion 26 March 5th, 2010 07:52
Tick, Tick, Miss Professor Bobo OEM Tech Discussion 1 July 26th, 2007 00:14
98 Cherokee starting to TICK TICK TICK...What is wrong? joey99jb Modified Tech Discussion 16 January 1st, 2005 21:40
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
