Old April 16th, 2018, 07:49
tchase tchase is offline
Any spark plug gurus?
Ok... So it's time for a tune-up on the old XJ.
Wondering if anyone can offer any advice regarding what plugs to run and/or what the difference is between the 2 different plugs that are spec'd.
I have an '85 with a 2.5L long-block from an '02 Wrangler. Manifolds, fuel, and ignition systems are stock(ish) '85.
The OE plug for the '85 is Champion RFN14LY
The OE plug for the '02 is Champion RC12ECC
Do these 2 plugs physically interchange? My gut says go with the '02 plug as I'm sure it will physically fit but I really don't know much about plugs.
Old April 16th, 2018, 08:19
RCP Phx RCP Phx is offline
Re: Any spark plug gurus?
Here you go!
https://www.sparkplugs.com/Data/uplo...ing_System.jpg
Old April 16th, 2018, 09:22
Thanks... But I can't get the link to work.
Old April 16th, 2018, 10:24
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Since RFN14LY are available, that is what you should use.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old April 16th, 2018, 11:11
jeep ride's Avatar
jeep ride jeep ride is offline
Link not working
Old April 17th, 2018, 20:22
lawsoncl lawsoncl is offline
Originally Posted by jeep ride View Post
Link not working
Bascially identical except the RFN14LY is a hotter plug (14 versus 12). I suspect the 02 ECM runs things a touch leaner and hence needs a "colder" plug.? If in doubt, I would go with the colder RC12ECC plug as too hot can cause detonation and potential damage versus too cold just fouling the plug.
https://www.sparkplugs.com/product.aspx?zpid=8592 (RFN14LY)
https://www.sparkplugs.com/product.aspx?zpid=8519 (RC12ECC)
Old April 18th, 2018, 06:55
Perfect! Exactly the info I was hoping for. Thanks so much.
spark plug? sbxj OEM Tech Discussion 3 June 27th, 2009 17:37
PulStar Pulse Plug - spark plug danny Benavidez OEM Tech Discussion 5 June 29th, 2008 17:30
No spark plug gap? hudsxj OEM Tech Discussion 22 November 27th, 2006 11:04
spark plug help j99xj Jeep Street and Performance 8 September 27th, 2006 14:08
Spark plug? TBLimited Modified Tech Discussion 1 February 15th, 2005 16:58
