Old April 14th, 2018, 20:06
Lake919 Lake919 is offline
KJ rear discs on my XJ 8.25
Hey guys, so I have decided to go ahead and pull the trigger on replacing the garbage rear drums on my XJ, I have heard that the KJ swap is a direct bolt on swap, so I figured this would be the way to go. What I am wondering is what all I need to complete this swap. Iíll list what I think Iíll need and if anyone knows of things I am missing please let me know. Thanks again as always for your informative help.
KJ backing plates
KJ parking brake cables
Rotors
Pads
Calipers
New wheel studs?
Parking brake shoes
anything else? I plan on buying all new parts.
Old April 14th, 2018, 20:25
two_door_rob two_door_rob is offline
Re: KJ rear discs on my XJ 8.25
You'll definitely want longer wheel studs. I used xj front studs for mine. You'll also want the hardware from the kj backing plates, it is slightly longer. You'll need new hard brake lines for the rear, or shorten the ones that are there and re flare them. You'll also want soft lines, i used wj, but I had to do some slight grinding for them to fit on the caliper, I believe zj ones work as well. That's everything I can think of, just did this swap a few months ago.
Old April 14th, 2018, 20:44
RCP Phx RCP Phx is offline
I have no idea about the KJ parking brake cables fitting, I went with MORE for those.
Old April 15th, 2018, 04:57
Jim Malcolm Jim Malcolm is offline
You need a disc-disc proportioning valve. I just swapped the guts from a ZJ valve into mine. Works great.
I'd replace the wheel bearings and seals while there since the shafts must come out. I'm very pleased with the Lubelocker gasket, although i do have an aftermarket cover so it's a lot stiffer than the stock sheetmetal. I can't say how well they work with the stock.
Old April 15th, 2018, 06:54
Now would be a good time to upgrade to at least 29 spline axles while your there!
I thought you were going to use Rubi axles?
Old April 15th, 2018, 08:23
Fore Wheeler's Avatar
Fore Wheeler Fore Wheeler is offline
Past MWC President
Mine worked with the XJ prop valve.
I used WJ soft lines to the caliper.
Longer wheel studs a must.
I never hooked up the e-brake.
member #285
My build thread: Out of Misery II
Old April 15th, 2018, 10:47
I am going to be using Dana 44ís but Iím getting them from a buddy and they are fully built. He was supposed to already have his new axles but something happened so taking possession of them has been put on hold until the end of August. I wouldnít waste my time but Iíll be towing my boat and Sea-Doo a lot this summer and the braking ability with those is deplorable.
Old April 15th, 2018, 11:04
sinat01's Avatar
sinat01 sinat01 is offline
im gonna be using the stock XJ parking brake cables when I do mine.
Old April 15th, 2018, 11:21
How do you use the stock cables?
Old April 15th, 2018, 11:42
Kego814's Avatar
Kego814 Kego814 is offline
Dont plan on finding new brackets. You can only get them from the dealer and they're like 300 a piece. I opted for the an disk swap because the timing was right.
Sent from my LG-H830 using Tapatalk
Old April 15th, 2018, 12:54
sinat01's Avatar
you can either rig them up using cable clamps, weld them, or the flop shop off-road makes brackets for a 8.8 swap, that would work too
Old April 15th, 2018, 13:21
Or just get the correct ones for a perfect fit and function!
Old April 16th, 2018, 11:15
Rcp, do you have a part number for the correct ones?
Old April 16th, 2018, 14:20
sinat01's Avatar
https://theflopshopoffroad.com/produ...cable-adapters
Old April 16th, 2018, 14:27
Those decrease your leverage and increase travel on a system that barely works when 100% right!
Rear Discs chvynova-71 Arizona For Sale/Wanted 31 July 15th, 2013 17:50
Rear discs steve-o Modified Tech Discussion 8 February 10th, 2008 10:40
Rear discs & ABS Chancer Modified Tech Discussion 7 September 15th, 2006 05:36
rear d44 discs AND abs? gregclimbs Modified Tech Discussion 1 April 6th, 2005 18:16
TSM rear discs on D44 NMCruser Modified Tech Discussion 3 April 4th, 2003 04:52
