Old July 31st, 2012, 05:16
XJSteven XJSteven is offline
RPM's jumping around
Any idea what could cause my RPM's to start jumping around sometimes when I'm driving along? I've replaced the TPS and tried swapping a few sensors over (02 sensor, camshaft sensor, coil etc) but it made no difference. I adjusted the throttle valve cable and tested the transmission solenoids with an ohmmeter and they look fine - although the fault I'm experiencing is intermittent.
It could be the torque converter locking and unlocking. I've searched the forum and a couple of possible causes are faulty brake pedal switch or a vacuum leak.
Sometimes when I put my foot down the RPM's increase like it's dropped down a gear but there's no power or acceleration (like it's being held back).
I might play around with the brake pedal switch and change the transmission oil and filter. Is it worth changing the solenoids over while I'm doing the service?
Old July 31st, 2012, 22:10
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: RPM's jumping around
Geez, steven. It would be nice if you had posted your Jeep info in this post or at very least in your profile along with the location of Earth.
Old August 1st, 2012, 00:08
I have a Jeep Cherokee XJ 4.0L 1996 model.
Old August 1st, 2012, 05:24
cruiser54's Avatar
When you mention low power, I think of a possibly clogged catalytic converter.
Never hurts to change the fluid. It's due to be done every 30,000 miles anyway.
What does your fluid look like?
It's not necessary to pull the pan as there is a screen, not a filter, in the AW4. You can just drain it using the plug and refill with 3.75 quarts of Dexron.
Old August 1st, 2012, 21:14
Thanks. It looks like it could have been the brake pedal switch that needed adjusting. Must have been confusing the Transmission computer into thinking I was braking.
JUmping the XJ Egodfrey North Atlantic Chapter 16 October 12th, 2011 11:06
Think he was jumping?? mattyj SoCal Chapter 10 July 14th, 2009 21:53
Jumping while driving.... Retep Draw OEM Tech Discussion 6 March 13th, 2009 06:37
Jumping Ship? buschwhaked Colorado Chapter 4 April 16th, 2008 22:31
Oil Pressure jumping? fizassist OEM Tech Discussion 6 August 5th, 2004 06:03
