Old February 9th, 2012, 21:00
CherokeePride99 CherokeePride99 is offline
Re: HP Dana 30 Pattern Check.
Bump
Old February 12th, 2012, 10:52
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
That's a good pattern, I'd run that.
Old February 12th, 2012, 13:29
XJ jay XJ jay is offline
backlash looks a bit tight now, whats it at?
Old February 13th, 2012, 07:19
bobnoxious's Avatar
bobnoxious bobnoxious is offline
Pattern looks good to run. Set preload, backlash, and run it.
Old January 4th, 2018, 19:12
bridgerx bridgerx is offline
5 years later I found this thread very helpful, bought the thinner slinger and made up the difference with shins behind the bearing race. In shopping around for those shims, though, I found myself at the jeep dealership. They have a cd case full of slingers in different thicknesses in 0.001 increments. If you had a pinion depth measurement tool or trusted your math on the marked dimensions this would be the way to go. Doing this in my garage over multiple iterations I found it easier it pop the bearing race out of the housing than to pull the bearing off the pinion. Just thought someone might find it helpful to know dealerships stock different thickness slingers.
D30 Pattern check menos Modified Tech Discussion 30 January 27th, 2012 17:36
Dana 44 Gear Pattern Check Please Begster Modified Tech Discussion 25 July 31st, 2008 20:51
D44 Pattern Check Please racer32 Modified Tech Discussion 8 April 20th, 2008 01:27
pattern check please massxj Modified Tech Discussion 7 May 16th, 2005 22:05
Please Check my D30 Pattern ChuckD Modified Tech Discussion 20 March 22nd, 2004 21:08
