1. Is anyone using (or used) a remote transmission filter on their AW4 transmission?
2. If so, does it create any backpressure that would cause a seal to start leaking, or cause premature failure of the transmission pump?
3. Does the remote trans filter (specifically the B&M Universal Remote Trans Filter) provide excellent filtering of the fluid? I flush my trans fluid every summer (20,000 miles or so).
4. Are these remote filters even worth it?
5. Where do you all have it mounted?
I am about to install the B&M Universal Remote Transmission Filter on my AW4and want to make sure it will not cause any problems, or may just return it if I find out from you all that it sucks.
Thanks.
2001 XJ 183,000 miles
Thanks.
