Today I went to plug something into my cigarette lighter and nothing happened. First response was to check fuses, not knowing which one it ran of, I pulled every one. Much to my happiness one was wet. It was brake fluid.
I looked an sure enough my clutch master is leaking. Now only one blade of the fuse was wet, I tried to get everything as dry as possible (didnt see too much at all) I taped a rag aorund the master above the fusebox, and put one above it to stop it from gettnig to the fusebox.
My question is, am I screwed, do I need to replace the fusebox?
Is getting a used master a bad idea?
