Old March 29th, 2016, 09:35
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: BUILD: My 1987 "Wagoneer" XJ Limited
Originally Posted by Phil View Post
I have a 1989 Wagoneer Limited. The driver's seat is in pretty rough shape. It was driven for a while apparently with a broken mount, and it has 219k miles anyway.
I know you scored a set of covers, but any guidance on fixing or replacing a badly worn seat?
How about a very worn leather wrapped steering wheel?
It's got the awesome oxblood/cordovan interior.
You are screwed on the steering wheel. I finally just used a slip on cover. The OEM is thick wax under the cover, about 3/8" thick all the way around and a very small metal rim under the wax, about 3/8" thick. The wax will fall apart if you uncover it
I found a cherokee with the same trim as my wagoneer. Plan to swap the seat/back only, keeping my electric seat hardware under the seat.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old March 29th, 2016, 09:39
Ecomike's Avatar
NAXJA# 2091
Originally Posted by Crist Clapper View Post
Sunset Chrysler Dodge & Jeep @ 662-226-5124 may have one each. Reference part numbers 56001528 & 56001529.
Have you or anyone with a Wagoneer installed an aftermarket headlight-relay harness to take he power load of the POS headlight switches that never last???? If so where did you find the harness? Part number? The cherokee harness is for 2 bulbs, with different pin styles than the 4 bulb wagoneers. The Cherokee is a 3 pin single bulb. The wagoneers are two pin, with different pin styles so the low beam and high beam can not be swapped by accident.
Old March 29th, 2016, 11:07
Crist Clapper Crist Clapper is offline
NAXJA Forum Supporter
Originally Posted by Green Mesa XJ View Post
FYI since these is some love for the old Wagoneers here I thought I'd post this: there is a someone in my area with a 1986 XJ Wagoneer for sale on craigs list, yes that means the 2.8 V6.
Thing is he wants almost $8 grand for it. He says check the NADA to justify his pricing.
I got sticker shock just glancing at it.
BTW I don't think the 2.8 is a necessary bad motor, a bit gutless and just not a good as the 4.0, but I never could kill mine it was the "bad" version of the motor with at least 200k I put on it.
What is the Craigslist link? I'd love to take a look!
1971 Ford Mach-1 ~ Restoration in progress
1987 Jeep XJ-Limited ~ Restoration just started
1990 Jeep Grand Wagoneer ~ Restoration just completed!
2007 Jeep Liberty ~ 2007 Jeep Commander ~ 2008 Jeep SRT
Old March 29th, 2016, 11:19
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is online now
sure .
https://pensacola.craigslist.org/cto/5509412173.html
I do have to say the Weber 38/38 DGES they put on they 2.8 is a good one
Old March 29th, 2016, 11:47
Steering-wheels often are on, or come on, eBay. Keep checking!
http://www.ebay.com/sch/i.html?_odkw... oon&_sacat=0
Seat-covers can be repaired at a local Upholstery-shop. If you want OEM material... Try Kevin @ 586-727-2486 @ originalauto.com
sure .
Thanks!
Old March 29th, 2016, 14:33
iluv83vettes's Avatar
iluv83vettes iluv83vettes is offline
RRC Treasurer
You should also be able to get the steering wheel redone to original at an upholstery yup place. I remember on an episode of Wheeler Dealers they had one redone.
1999 Limited 4.0, AW4, NP242w/Tom Woods HD SYE, trussed dana 30, 8.25w/ZJ discs, OME/JKS/DPG 4" upness, JK take off wheels, Spectre cowl intake, Genright 30 gallon fuel tank, ARB Bull Bar with Warn M8000, JCR Rear Adventure Tire Carrier, WJ knuckles with DOM steering, Black Magic brakes all around
Still need to: truss, shave, relocate shock mounts on the 8.25; Regear with selectable lockers; 2x6 rockers, belly skids, rewire "stereo" ...
Old March 29th, 2016, 14:54
Hope nobody minds me asking this here. I need to find a new/another fuse box for my 85 waggoneer. Clutch was leaking and it looks like crap.
Part number J4179458
Looks like it is 1984-1993 which is good, but I'm having hard time finding one in good shape.
Some NOS were cleared out not too long ago. Don't see any around now.
Anyone have a lead on these?
Old March 29th, 2016, 15:21
Did you try these folks: http://www.jwjeep.com/
Old March 29th, 2016, 15:28
No. Was not aware of them. Being in California they should have some decent parts. Thanks
Old May 7th, 2016, 19:08
gr8Tyres's Avatar
gr8Tyres gr8Tyres is offline
I plan on using this thread on my 89 Waggy. It looks pretty comprehensive, so thanks for pix and explainations. My beast runs well, but steering is vague. I think trackbar and bushings may be bad, there's 2-3# play in wheel. Who knows until I start picking it apart.
I'll definitely need some front seat covers in tan, but seat controls seem to still work.
I'll keep in touch.
Tom
Old May 7th, 2016, 19:14
gr8Tyres's Avatar
Me again,
Did you put down any Dynamat under carpets? I'm thinking of doing this, but $$.
Old May 7th, 2016, 20:07
RRC Treasurer
Originally Posted by gr8Tyres View Post
Me again,
Look up peel n seal from lowes
Old May 7th, 2016, 20:15
Ecomike's Avatar
NAXJA# 2091
Thanks!
I just ran across a huge cache of old Renix era Wagoneer photos. Gotta love em, they looked awesome. I need to restore that look on mine.
http://www.cargurus.com/Cars/Jeep-Wa...-Overview-d493
Old May 8th, 2016, 15:03
gr8Tyres's Avatar
I luv83Vettes: sounds as an alternative, but will it smell much being near floor temperature? Price seems righ tho.
I'm also hearing about NOICO stuff.
XJ: 1987 Wagoneer Limited Or? Windshield trim? Crist Clapper Wanted: Private Party Only 5 November 13th, 2012 17:41
1987 Wagoneer XJ Limited - Trim color? Crist Clapper OEM Tech Discussion 5 July 15th, 2012 17:11
Parting out: 1987 Wagoneer Limited YELLAHEEP For Sale: Private Party Only. XJ ITEMS ONLY 8 June 25th, 2007 23:55
Parting out 1990 XJ "Wagoneer" Limited XJ&CHZ4ME For Sale: Private Party Only. XJ ITEMS ONLY 14 December 16th, 2006 23:19
1987 XJ Wagoneer 6.5" Lift on 35`s + Extras Fairmonco For Sale: Private Party Only. XJ ITEMS ONLY 12 September 15th, 2006 16:37
