Old October 7th, 2017, 16:07
doostica's Avatar
doostica doostica is offline
HELP! 96 XJ 4x4 CPS bolt...in the bellhousing
So I dropped the bolt to the CPS in the bell housing when swapping out my cps... I've read on previous posts here and on other sites, some people say It can be left there and it will get destroyed on it's own....
I cannot find the bolt, for all I know it could I suppose have ended up in some corner area that I cannot see, but I'm pretty confident it's in the bellhousing.
To make a long story short, I live in a gated community, in an area where I am not allowed to do work on my vehicle, however I tend to do it when the night staff for resident services/security is at at slowest, so taking the Jeep apart is a real task.......
Can I leave the bolt in the bellhousing as I've read previously?
96 XJ 4x4 Automatic
Old October 7th, 2017, 18:22
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: HELP! 96 XJ 4x4 CPS bolt...in the bellhousing
This sounds like a familiar refrain.
http://www.naxja.org/forum/showthread.php?t=1141737
Try fishing, leave your magnetic wand behind and see if you get lucky too.
Old October 8th, 2017, 14:46
doostica's Avatar
Yeah, I read that, and I've read other threads about it, as well as some saying that it's ok to just leave it in there and it'll get chopped to bits but I was hoping for someone who's actually left it in there and it's not done any damage... I don't have a magnetic telescoping pole...ordered one and it won't be here until Tuesday. I was hoping to just leave it in there and it'll perhaps fall to the bottom and stay there, but I don't know.
thanks for your reply
Old October 8th, 2017, 18:51
lawsoncl lawsoncl is offline
Pretty much everything in there is going to be softer than the bolt. I've dropped one in there before, and after turning the crank with a wrench, it dropped out the bottom. I won't be comfortable leaving it in there myself.
Old October 9th, 2017, 06:52
cruiser54's Avatar
cruiser54 cruiser54 is offline
I'm not endorsing doing so, but I have left one in there before. about 5 or 6 years ago. still driving it.
Old October 9th, 2017, 12:21
doostica's Avatar
Thanks for the replies....
I am going to leave it for now, and hope for the best. If I can get by with it in there (after I figure out why it still won't start now that I've put in a new CPS) I'll take it a few hours to someones place that has a garage and all the tools I could need to tear it down to get to the bolt and get it out.
For now though, I have to figure out why it still won't start...
In the past year most of the following were done, some just over a year ago.
New cps, battery, alternator, new starter, ignition switch, ignition coil, distributor cap, plugs and rotor. New idle air control, power steering lines, o2 sensors, many other sensors, new radiator, water pump & thermostat, fuel filter, oil pressure sending unit, and I just took the NSS out and cleaned it and put it back together; looks great. Many other parts as well, I always buy Mopar parts direct from the chrysler dealer if the price isn't insanely excessive.
Based on those things, I am going to assume, it's most likely the something associated with the fuel sending unit in the gas tank/ fuel pressure regulator or fuel pump. I'm at work but I'll go for a jog to walmart (the only place near me within 15 miles, its about that far) and pick up some spray to blast the intake to see if it'll start.
I am as perplexed as can be. One day I'll figure it out.
For the past many months, before this happened it would die at every single stop, although i can leave it parked start it up and it would idle and never die. I would throw it in neutral when I'd come to a stop and then put it back in drive to go. Some slight stuttering on occasion when I'd begin to drive again.
-Thanks again for your input
Jessica
Old October 9th, 2017, 13:42
Anak's Avatar
Mostly Harmless
I suppose spraying starter fluid in the intake will give you a good clue. A fuel pressure gauge is really the correct tool though. Even if it sort of starts/run on starter fluid you still won't know if it is fuel pressure itself or a lack of signal to the injectors.
I would suggest you rent a fuel pressure gauge from an auto parts store. You should be looking at 49 psi at the Schrader valve on the fuel rail.
Old October 10th, 2017, 14:44
doostica's Avatar
Where would the schrader valve be found? My fuel sending unit has the pressure regulator and pump etc all on it, which is in the gas tank.
Old October 10th, 2017, 15:21
Anak's Avatar
Mostly Harmless
It is on the fuel rail. See the red line with the brass fitting on the end of it here:
It looks like it is several inches back from the fuel line connection on the rail.
By the way, that red line with the brass fitting is my fuel pressure gauge. Ideally you will be looking for a metal cap where that brass fitting is. That is assuming someone hasn't lost the metal cap. Try to keep that Schrader valve capped so that dust/debris don't get in there and mess with the seal.
transmission bellhousing bolt pattern CAD wanted diesel-xj Modified Tech Discussion 2 November 17th, 2013 13:11
help! cracked bellhousing and bolt hole on motor 995speed OEM Tech Discussion 9 June 4th, 2013 09:31
Bellhousing bolt size H8PVMT OEM Tech Discussion 6 April 29th, 2013 13:06
Bellhousing Bolt Questions IcedXJ OEM Tech Discussion 7 June 3rd, 2006 22:37
CPS bolt in the bellhousing.... vegard OEM Tech Discussion 13 September 29th, 2005 19:20
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
