Old August 9th, 2017, 19:02
lordoeuf lordoeuf is offline
How to tell of factory Durango box is plow or non-plow version?
Is there any way to determine if a '98 Dodge Durango steering box in vehicle at the junkyard was the plow or non-plow version? From the reviews, it seems like the plow version may be the way to go on an XJ.
Ordering reman boxes, you can specify plow or non-plow, but how to tell about used boxes at the junkyard if they are plow or non-plow just by looking at the box?
Old August 11th, 2017, 10:48
burntkat burntkat is offline
NAXJA Member #1145
Re: How to tell of factory Durango box is plow or non-plow version?
Don't know where you get the idea the plow version is the one to go for. Everything I've seen has been quite specific in that it's the NON-plow-prepped piece.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old August 12th, 2017, 03:26
From this thread and a few others,
http://www.naxja.org/forum/showthrea...=915103&page=8
I went ahead and bought a '98 Durango gear box from a salvage yard. It has about 2 3/4 turns, lock-to-lock. I was hoping for the 3 3/8" turns unit, which I understand was for the plow version.
How do we tell from the markings on the box itself if it is for plow or non-plow?
Old August 12th, 2017, 15:30
ftwelder's Avatar
ftwelder ftwelder is offline
I wonder if Dodge used a shorter pitman arm and the same box with stops removed for the snow plow version to make more steering power. Mine was from a 98 non-P and used a variable rate gear and internal stops in the box preventing a full 90* rotation. I think the only way to tell is ratio and degrees of articulation.
endless jeep project that will eventually end up as a rust bucket in someones backyard.
So What if I Don't Plow? banderso Midwest Chapter 6 January 19th, 2015 14:17
looking at xj with a plow mcguyver_xj OEM Tech Discussion 2 February 17th, 2014 18:28
Looking for 6' plow Jeepm@n MWC For Sale/Wanted Forum 1 June 13th, 2011 23:07
Anyone plow with their XJs ? camarors8992 Modified Tech Discussion 16 December 26th, 2009 20:32
86 f 150 4x4 w/plow parting out waggy For Sale: Private Party Only. XJ ITEMS ONLY 0 September 4th, 2004 13:00
