Old November 14th, 2017, 15:34
themauler's Avatar
themauler themauler is offline
Re: XJsportG's "How'd I get here" build
Entertaining thread. I will be following down your path shortly. Starting to plan the axle parts gathering, build them, and throw them under and weld them in. I'll have to add steering assist and take care of brakes but I will be closely watching this.
I am looking for a pre super duty dana 60 axle with Ball joints to keep the maintenance simple. The rear axle is still a question mark!
Old November 14th, 2017, 17:33
XJsportG's Avatar
XJsportG XJsportG is offline
SouthEast #4328 (RVA)
Originally Posted by Exxon Valdez Jeep View Post
If you do any kind of high steer, you'll want to raise the trac bar mount on the TnT truss. Nice stuff, keep it up!
That's plan. I figure I would do the OTK mount to start and go to a High-Steer mount if needed, which I probably will.
Originally Posted by Heavyopp View Post
so what are you thinking with the dana 30 your taking out?
I could be interested if your going to sell it -- I'm in Jersey, driving down to get it wouldn't be unrealistic
Currently, I have a friend lined up to but the housing and gears. I am going to be keeping the Reids and outers for now.
Thanks, the BJ 60 would be a good axle, only downside I think there is limited options for aftermarket knuckles. I have a PSC steering box and hydro assist kit that'll go in once I get the axle in.
If I could do the rear axle again, I may have gone with a Dana 60 from a E350 with disc brakes. The spindles would fit the 35 spline shaft so you don't have bore them out.
RVA
Old November 14th, 2017, 20:43
themauler's Avatar
4wheelsupply here in VA will machine and install a hi steer arm on your knuckle for under $200 I believe. They look beef. I am aware those knuckles arenít the strongest but there are kits with a little bit of welding you can make them beef for cheap.
Old November 15th, 2017, 09:12
XJsportG's Avatar
Not a bad deal when you can get the BJ 60s a bit cheaper.
Hindsight 20/20 I may have gone with a 05+ Superduty 60 if it was the right price.
RVA
Old November 17th, 2017, 08:26
freerider15's Avatar
freerider15 freerider15 is offline
Looks like a good list, and good start!
XJ Buggy On Tons
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 268 January 15th, 2018 18:38
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
