ManNamedJed
- Reno
Well I fixed it!!
I looked in the distributor again to to take a look a the dist pick up (someone said that might be an issue). I pulled off the rotor (which I hadn't done before) and the tab that holds in position was broken, which allowed it to rotate about 10 degrees. I dug up an old one (I had 'upgraded' it a few years ago) popped it on, and now it runs fine.
Thanks everyone for their help. Glad it turned out to be a simple fix. Looks like I'm just out the cost of a valve cover gasket.
