Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old October 19th, 2017, 10:37
kap009 kap009 is offline
Re: Need help diagnosing rough running 89
Well this got interesting. Pulled the valve cover this morning and found this special treat...
Put it back in place, put everything back together and it runs like it used to but is still ticking.
Old October 19th, 2017, 12:45
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is online now
Did you pull it out to see if it is bent or anything?
Old October 20th, 2017, 16:01
my2monkeys my2monkeys is offline
Cant see the pic. Was anything loose on the valve train. The rockers? Could you spin the push rods with your fingers?
Old Yesterday, 10:09
1990JEEPXJ's Avatar
The picture showed a rocker that had moved over off of the push rod. Not sure why the picture is gone. I saw it the other day
Old Today, 16:09
90xj06's Avatar
90xj06 90xj06 is offline
do you have a video of it ticking now? its possible that rocker or rod is damaged or bent.
99 Running very rough jeffreylane OEM Tech Discussion 12 March 30th, 2017 08:04
help diagnosing rough idle (this should be fun) bldeagle10 OEM Tech Discussion 13 June 26th, 2011 15:30
running rough 98xjclassicblue South East Chapter 16 July 7th, 2010 18:10
Rough running after 4-lo LiamN Modified Tech Discussion 6 March 23rd, 2008 15:46
Rough Running jokerjosh OEM Tech Discussion 1 January 31st, 2006 08:07
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
