Hey Guys,
I had a Durango Gear box but wanted to to add Hydro assist so I picked up a 2001 stock XJ box at a gearbox, tapped it, rebuilt it and installed everything. After which the hydro assist works well but I have a big flat spot in the steering. When I turn the wheel the input shaft turns but the pitman arm does not for a bit. Any idea what I might have done wrong on the rebuild? All 24 balls were put back in order and I changed all the O-rings and seal that came in the kit.
Thanks
Thanks
