Old March 12th, 2008, 16:52
AaronJXJ AaronJXJ is offline
battery opinions
ok so the battery in my xj is shot
if i leave the doors open for 20-30 min, its dead
it seems like a popular choice is optima
but i was curiouse as to what else is out there
what do you guys recomend?
and what makes optima such a desirable battery?
thanks for your input
Old March 12th, 2008, 16:57
RCP Phx RCP Phx is offline
Re: battery opinions
The best part about any AGM battery is the "physical" abuse they can handle!
Old March 12th, 2008, 16:58
terryd's Avatar
terryd terryd is offline
Optima has its acid absorbed in fiberglass matting to make it a spill proof design. The same matting has the feature of helping to secure the plates in place making them more vibration resistant. This being said, I run an Autocraft Titanium from Advance Auto in my jeep, car, farm trucks, and tractors. going on 7 years for the one in my 50hp Kubota with one recharge and no failures. Jeeps in almost 4 years old and has never failed to start. 3 yr free replacement and 84 mos prorating.... My $0.02
Old March 12th, 2008, 18:15
tgoff's Avatar
tgoff tgoff is offline
I recommend Odyssey for sure after seeing one in use. Actually it was a Sears Die Hard Platinum but they are the same as Odyssey, made by the same company, and have identical specs. At Sears they cost less and have a better warranty so its a good deal plus it puts them at less money than a Optima. Do a search on the web and you will find a lot of people who prefer Odyssey over Optima plus a lot more problems with Optima then Odyssey.
Here is the batteries I am talking about
Odyssey http://www.odysseybatteries.com/battery/pc1500.htm
Sears Die Hard http://www.sears.com/shc/s/p_10153_1...wor d=battery
MY BATTERY OR WHAT!?!? sigh sack Modified Tech Discussion 7 December 22nd, 2006 16:54
battery wilson OEM Tech Discussion 4 December 30th, 2005 00:13
Whats killing my Battery ?? dual battery system MACH90XJ Tow Rigs and Trailers 3 July 27th, 2004 17:26
Where's your battery? Speed_racer OEM Tech Discussion 5 January 20th, 2004 10:19
battery? DARKFLY OEM Tech Discussion 3 November 5th, 2003 11:47
