N8N_99xj
- Berwyn Heights, MD
I have a 2000 XJ, 4.0, about 260K miles
it runs SUPER strong and quiet. I just replaced the VCG with a new Fel-Pro and now that it's not pouring oil out there I see that I have a leak on the pass side of the engine. It's either leaking from the head gasket between 3 & 4 or else oil is being thrown out around whatever that is in the distributor hole. Suspect head gasket. Also: I did not see any casting numbers on head when I had VC off so possible head has been replaced.
Is this a real concern? Am thinking I'll take VC off again and torque head bolts and if it still leaks then just let it leak, is that a problem or opening myself up to possibility of failure? I don't want to put a lot of money/effort into this thing as I'm hoping my finances turn around soon and I'll be able to sell this and buy a better vehicle at some point, but I was desperate when I got this.
Additionally, I have a coolant leak that I initially thought was the thermo housing but now it looks like it's actually the WP gasket. Am thinking to just replace both to cover my bases. If I have to pull water pump not knowing the history of this guy I'd as soon replace it than reinstall an unknown miles old one. Who makes a good, reliable WP for the 4.0 at a reasonable price? I've already got a thermo gasket and a new Robert Shaw thermo.
thanks!
thanks!
