Old April 12th, 2018, 13:50
patnok patnok is offline
'92 XJ 4.0 not idling correct
so it stated this almost stalling & then reving up to 1500rpm....changed idle control valve,map sensor & throttle position sensor.....no change...
Old April 12th, 2018, 20:02
freggie freggie is offline
Re: '92 XJ 4.0 not idling correct
check for vacuum leaks on intake manifold, rubber and plastic lines. I had a small vacuum leak on the intake manifold, very small hole and it made my jeep idle at 950. Used electrical tape and now it idles fine
Old April 13th, 2018, 08:33
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Don't forget the vacuum reservoir - if you have a stock front bumper, it's tucked inside that on the passenger side, is about 5 inches in diameter/about 8 inches long.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old April 16th, 2018, 16:52
Smile Re: '92 XJ 4.0 not idling correct
it was the PCM............thanks for everyone's ideas! I know a lot of stuff that is now new & & did some over due maintenance.
ps, jeep hasn't had that canister for years!
Erratic idling bigalpha OEM Tech Discussion 154 August 29th, 2009 21:25
need help with a rough or low idling xj.... milehigh OEM Tech Discussion 12 July 27th, 2009 02:36
Idling question bosco01xj OEM Tech Discussion 8 July 17th, 2009 10:27
Vibration at idling guther66 Modified Tech Discussion 6 March 11th, 2004 18:38
Not idling quite the way I want it to Ecarlcl OEM Tech Discussion 2 February 27th, 2004 20:45
