- Billings MT/Rapid City SD
ok I changed the fuel pump out and now my gauge isn't working right. It works just not accurate. I now the manuel said to be careful with the sender unit on the side of the pump and I did bump it a little bit on the side of the tank when taking it out but nothing real hard and the float I don't belive got bent. Should I replace both the float and the sender, or what. How should I go about trouble shooting this so I don't have to replace more parts then I need to. The guage will read full when the tank is full and is somewhat accurate untill about half tank(100mi), then it just drops to 1/4 after a few miles(125) and stays there(200-220mi).
