Old February 11th, 2018, 12:15
alexgalexg's Avatar
alexgalexg alexgalexg is offline
Loss of amp gauge then squeek and smoke
Well here I am again. Posting almost daily at this point. So my 1998 Jeep Xj is having an interesting problem. I was driving down the road when I hear this loud squeak. Only happens once and I loose my amp gauge. Roughly one minute later the belt slips for one and a half seconds. After that something under the hood just gained a steady chirp. Mind you every component under the hood is less than 6 months old.... I get home and shut the engine off and some smoke or steam just begins to come out.
Before you come to any conclusions please watch this video I uploaded about it.
https://youtu.be/gCIE1A4uTJA
Old February 11th, 2018, 13:11
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: Loss of amp gauge then squeek and smoke
Steam_ Cold ,wet ,rain on hot radiator....heat raises steam flows outside.
No volts,chirp/loud squeal= shot alt or at very least a way too loose belt.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old February 11th, 2018, 13:25
Hypoid's Avatar
Hypoid Hypoid is offline
Remove the belt, rotate every pulley by hand, you will have a starting point.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old February 11th, 2018, 13:55
alexgalexg's Avatar
Thanks guys. It started raining pretty hard so I couldnt get out there today but I will do so tomorrow morning. Id like to see if I have any current going to the battery too. I guess thats what I get for being an idiot and going to napa instead of rock auto
Old February 11th, 2018, 15:05
lawsoncl lawsoncl is offline
You're "losing the amp gauge" because the belt isn't driving the alternator pulley. Either the belt is too loose and slipping when it gets wet or that brand new chinese-made alternator is seizing up.
Old February 11th, 2018, 15:09
alexgalexg's Avatar
I will confirm tomorrow. But when an engine with one belt driving everything has a totally seized pulley you are usually greeted with a ton of burning rubber smoke and a very loud shriek. I have a feeling it did seize for a split second in those two instances and is now chirping but spinning. I guess its not producing power anymore either but I will test that tomorrow. Glad I have another Xj to get to my 8am appointment tomorrow!
Old February 11th, 2018, 17:32
blakews2217 blakews2217 is offline
I lose my alt only when crossing deep water/heavy heavy heavy rain or running through puddles. I give it a minute to dry out and I hear a chirp and itís making power again.
Old February 11th, 2018, 18:18
alexgalexg's Avatar
I've only driven my 2 xjs since 2004. I have even driven through the ocean and very deep in during hurricane Sandy. Never have I lost amps or had to deal with chirping so that is very strange. But either way I don't want my jeep to be squeaky so if the alternator is the culprit I will buy a better one off rock auto
Old February 12th, 2018, 07:40
alexgalexg's Avatar
Started it up this morning and seems the alternator is working again. But I have a very loud chirp going on over there. It's hard to tell if it's the fan, the compressor or the alternator since they were placed so close together. I will have to drive on it a little more but I have a feeling that alternator is going
Old February 12th, 2018, 10:43
Dragonslayer Dragonslayer is offline
Harmonic balancer de-laminating? Paint a thin, continuous, white line across the front
face of the inside and outside rings. Drive the car and listen for any chirps. Shut down the
engine and check the harmonic balancer. If the painted line is broken, then the harmonic
balancer needs to be replaced (real soon).
Old February 13th, 2018, 00:07
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
I have had that issue when the bearing in the rear portion of the alternator goes bad. To help find out, spray each suspected squeak with WD-40. My money is alternator bearing.
Got a squeek Apostle Colorado Chapter 17 August 30th, 2010 21:49
Would backed out manifold bolts & smoke at the manifold burn oil & smoke at tailpipe? DonkRado OEM Tech Discussion 2 December 13th, 2006 22:11
Squeek!!! Squeek!!!! StylerG Modified Tech Discussion 1 May 15th, 2006 22:04
Squeek when in 4wd Jeffro600 OEM Tech Discussion 1 October 18th, 2005 18:13
Squeek when AC is on LouisianaZJ OEM Tech Discussion 3 July 20th, 2005 11:16
