Old February 10th, 2018, 16:22
HttpWayne HttpWayne is offline
Excessive Low Idle
The XJ shut off mid-drive and has had an excessive low idle after the engine has warmed up. When turned on cold it idles at 750~, but right around 160 on the CTS it starts to lower gradually until it's idling at that bottom bar (500?).
I'm not sure if this is indicative of an IAC problem or not. It was previously stuck shut after having sat for over a year and I had to use a lot of heat gun and PB blaster action in cycles to get it to open up. I've been driving successfully with no problems for about a week now. I just had it out the same day it stalled (before it stalled) for other reasons and it was perfectly fine (as far as visual inspections go). I'm certain I don't have vacuum problems. Usually a loose or broken vac line causes excessive high idle since unmetered air is allow in. This seems like the opposite.
Old February 11th, 2018, 06:10
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Excessive Low Idle
Year?
Old February 11th, 2018, 16:07
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Could you have a lack of OEM designed vacuum leaks, like the rear CCV metering line being clogged? IAT temp sensor is dirty? Low fuel pressure.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old February 12th, 2018, 05:32
It's a 2000.
All OEM lines are connected, I haven't checked for clogs but I can't possibly fathom a reason I would have one in the PCV. It's only been running a week and it's a fresh rebuild.
It stopped doing it yesterday afternoon and went back to normal. I'm not sure what it was. But later on I went into the store and it sat for a while and turned on to go straight to very low idle, and it was reading very lean (18+). My gauge doesn't read past 18 so I shut it off and went to look around in the engine bay. I didn't see any disconnected lines or connector and the fuel hose was thoroughly pressurized based on feel. I started it back up and it was normal.
There usually aren't any coincidences and since it shut off just after I reconnected a water injection kit I think that had something to do with it. I hooked it back up yesterday afternoon and it locked up on my again so I disconnected it, but It didn't give me any idle problems. THe ironic thing is previously when I used it I had it connected directly to a manifold port before the supercharger and never had any problems with it. Now it's connected to the air box so it has more room to atomize and it keeps locking up. I'm beginning to wonder if it has something to do with wet sensors. That would make much sense because previously I also had it connected to the airbox at another time, and I could tell from the filter it certainly was spraying into it.
Old February 12th, 2018, 09:50
Ecomike's Avatar
NAXJA# 2091
Originally Posted by cruiser54 View Post
Year?
LOL, gotta love it, hey folks, I have a jeep with a low idle, whats wrong??????......later we get word it is a modified black box rig with god knows what else on it besides OEM stuff, like water injection and a supercharger, LOL.
excessive idle rocklobster87 Tow Rigs and Trailers 5 April 30th, 2010 23:36
excessive high idle BenDiesel OEM Tech Discussion 24 April 5th, 2010 11:59
New Guy, Excessive Blow-by on 89' 4.0 Heap O' Jeep OEM Tech Discussion 18 April 13th, 2009 09:57
excessive idle speed the_bandit87 OEM Tech Discussion 5 December 5th, 2006 19:18
Excessive NOx 93 4.0 h.o. CA XJ Damon Dimick OEM Tech Discussion 11 April 20th, 2005 02:28
