Old February 10th, 2018, 19:21
Jeff/Alaska Jeff/Alaska is offline
Re: Oil pressure gauge
Grounded wire ignition ON no change or movement still sitting on 0.
Old February 11th, 2018, 05:48
cruiser54's Avatar
cruiser54 cruiser54 is offline
NOW, we're getting somewhere. Facts vs conjecture is always good.
Gotta find why the gauge isn't responding.
I'm not near a wiring diagram at the moment. Perhaps check online and look for a plug somewhere between the wire at the sender and the gauge.....
Old February 11th, 2018, 12:03
lawsoncl lawsoncl is offline
Sounds like either the gauge is not getting power, or the wire between the gauge and the sender is shorted to ground.
Old February 11th, 2018, 14:21
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Oil pressure gauge
The gauge is not likely however these are 30 year old jeeps now.
Here is part of the diagram for the instrument cluster.
Oil pressure gauge
Old February 11th, 2018, 18:16
cruiser54's Avatar
Need to see "with gauges".
Old February 12th, 2018, 00:58
Thanks Green and Cruizer.
Old February 12th, 2018, 05:14
cruiser54's Avatar
C100 is the big bulkhead connector on the firewall side of the fuse box.
C105 is a flat 6 pin connector behind the battery. Light blue 20 gauge wire at terminal B.
Old February 12th, 2018, 09:32
Did you say you saw battery voltage on the wire going to the sensor with it unplugged? Voltage on the sensor wire with it unplugged would rule out a short to ground between the sensor and the gauge.
Old February 12th, 2018, 10:22
Oil pressure gauge
I should say the jeep trouble shooting book was for 1988, I believe Jeff/Alaska has a 1989. I think the difference will be slight.
He did say he cleaned out his bulkhead connector before, maybe there is a issue there.
Old February 12th, 2018, 10:47
cruiser54's Avatar
87 and 88 had the c101 connector and 89 and 90 did not.
Old February 13th, 2018, 00:41
Lawsoncl,
Yes there is full battery voltage at the sensor wire. Tested both on RUN/OFF and RUNNING. No difference full voltage at the sensor wire. At this point I am thinking that there is a bad connection to the gauge cluster, but not likely since ALL the other gauges are working but most likely is the gauge failed and suddenly.
Oil pressure gauge XJeeper87 OEM Tech Discussion 6 September 12th, 2010 19:59
Oil Pressure Gauge darkoverlift OEM Tech Discussion 4 April 28th, 2009 12:53
Oil pressure gauge malfunction or oil pressure spike? Daedalus454 OEM Tech Discussion 5 August 5th, 2008 22:09
Oil pressure gauge mudslinger4x4 OEM Tech Discussion 2 February 5th, 2008 08:34
oip pressure gauge help lenny OEM Tech Discussion 5 August 1st, 2005 16:07
