90xj06
- Peabody, MA
I have the dreaded cargo area leaks. I seem to contain the Atlantic ocean when it rains. My first step was to remove the roof rack and it's still the same. It's coming in through the piller on the driver's side. I have the rug and lower panels off and can't quite pinpoint it. I used some silicon to fill areas that had cracking filler on the hatch lip. But I haven't taken the cover off were the wires run in. I'm going to try and seal that tomorrow morning. But if that doesn't solve it where should I look next? I also sealed the tops of the tail light housings but it's coming in above that. Also does not leak at the window seals.
Side note anyone know the size of the rubber nut inserts and thread pitch?
