My axels
Sullie
el paso tx
How do i find out which axles I have...
Which axles are better...
1988 XJ 4.0 manuel
Sent from my SAMSUNG-SM-G891A using Tapatalk
Also, check the tag that's bolted to the front diff cover, that will tell you the ratio.
X2 on reading the axle faq thread linked above
Both are decent for everyday use on highways and light trails. If you go with decently bigger tires and start getting a little more adventurous on trails, just use them until they give out. If they dont, keep going. If they do, then upgrade.
