moparcyco
- Preston Idaho
This Is a two part question first as I am trying to get my coil/link mounts situated. I noticed maybe what appears to be a problem. In the picture you can see that the angle from the cross member to the lower link looks way off. Looking at the stock 30 the coil mounts are straight but the lower link mount is tilted inboard. Is this angle ok? Found a few pics online looks like any long arm has some angle what is acceptable? Or am I overthinking here? Almost looks like a mount on the frame rail would be better. This is a Tera 60 only 3/4 wider per side than stock D30
Question two is how much adjustment can you build into a link? Lets take a nice round number 40 inches center to center of the mounts. The threaded part of the johny joint is 3 1/4 both sides the weld slug are 1.5 how long should you cut the link? Is there a calculator online somewhere for this? Thanks
