I had working daytime running lamps on my 90 MJ...a DesignTech module that was working fine until this weekend when I installed my IPF upgrade lighting harness. It seems that the factory Jeep lights are a POSITIVE headlamp system (meaning 12 volts switched to the headlight and ground is constant) and the IPF's convert it to NEGATIVE (12 volts is constant and and the ground is switched)? Sound right? Please help, as I want to get these daytime running lamps working again! Thanks.
