Old December 3rd, 2017, 06:57
Dest's Avatar
Dest Dest is offline
Most comfortable 4-5" lift, primary street use
Been searching for about the past hour or so, but can't find any recent opinions. Jeep is primarily a DD, but does see occasional fun in the dirt. It currently has an ancient Tomken lift kit with Bilstein shocks and the ride is awful.
So, what's the best street riding 4-5" that won't be total shit offroad?
Thanks in advance.
98
AX-15
Old December 3rd, 2017, 07:37
TRCM's Avatar
TRCM TRCM is offline
Re: Most comfortable 4-5" lift, primary street use
long arms or drop brackets up front
shackle relocation brackets out back (or 4 link conversion)
not personally a fan of bilsteins on jeeps
Old December 3rd, 2017, 07:40
Dest's Avatar
Too firm? Or some other reason? What would you recommend instead?
Old December 3rd, 2017, 08:28
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Install long arms or control arm drop brackets. The more rubber bushings instead of flex joints, the better the pavement ride and noise control. BDS makes good riding lifts. I have an older Rubicon Express lift and have no complaints.
Your choice of shocks can make a huge difference in the ride comfort. Bilsteins tend to be firm. BDS, and DoetschTech DT3000 are good choices.
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 3rd, 2017, 09:24
ehall's Avatar
ehall ehall is offline
absolutely get what you pay for with shocks
my '91 beater rebuild
Old December 3rd, 2017, 12:26
TRCM's Avatar
Haven't swapped yet, but they are definitely too firm for my tastes.
I had bilsteins on my 97 dually, and those were awesome on it (which is why I got the ones I have now).
Been thinking doetsch tech for short term, I had them on another heavier vehicle (see avatar) and they worked well, so may try again.
If I finally decide on the suspension to go with, I may step up to fox shocks.
Old December 3rd, 2017, 13:55
cody4359 cody4359 is offline
I have a long arm setup and running bilstein 5125s. it's not nearly as plush as my f150 so I've been browsing my next setup. what I gather is im after a linear valved shock and will more than likely got to accutune offroad and have a set valved for me. my bilsteins don't like potholes or washboard's on the logging roads, pretty much any sharp abrupt bump
Old December 4th, 2017, 09:21
muddypunk muddypunk is offline
TOOL
I'm running 4.5"-5" I have adjustable uppers and lowers with poly and wish they were rubber, no DB for me I got all hung up one time so I sold them great for mall crawlers. Bastard leaves and Ruffstuff swap brackets for the 8.8 which lifted the rear like 3/4". Anyhow shocks I like hydro over nitro hydro are soft and float instead of bounce and rattle my teeth like gas (nitro) do they have a place in off road but not in what I do. I have cheapo Rancho 5000 I think but actually I forget but they have a monster shaft 5/8" and it rides so awesome on and off road but it really needs rubber bushings.
Sent from my Arse because my hands are full
Old December 4th, 2017, 09:23
burntkat burntkat is offline
NAXJA Member #1145
Concur all of the above.
I'm a huge fan of Doetsch Tech shocks. So much so that my rehab of my 90 XJ is going away from Rancho adjustables to "dumb" Doetsch shocks, likely the DT3000 series. As a bonus, they're about $40/shock.
You especially want to relocate the shackles out back. The factory location is extremely limited in range of motion, and the angle is horrid. This makes for a bad ride.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old December 4th, 2017, 09:50
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Switched from Bilstein 5100s to the 5165 series and saw a big difference in ride quality. The 5165s are more compliant at low speeds but still are well damped on hard hits.
You get what you pay for in shocks.
At 4"+ of lift, the drop brackets also make a significant difference in reducing harshness, producing a much smoother ride.
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old December 4th, 2017, 14:46
smokeyyank's Avatar
smokeyyank smokeyyank is offline
If you're going to DD and primarily be on road, I'd say keep it 2-3" of lift and hack the fenders. 4-5" you start having to consider a lot of other factors that you may not want to dump the cash in. SYE or tacse drop, steering geometry, extended brake lines, the list keeps going. 2-3" is pretty safe and easy and will net you some off road performance. Depending on your budget I'd go OME hands down for a great all a round lift and ride.
Old December 5th, 2017, 08:03
NAXJA Member #1145
Lazyxj- what in the world is a "towing baseplate"?
Old December 5th, 2017, 09:52
lazyxj's Avatar
NAXJA Member #1310
We have flat towed our 2001 XJ, behind a small motorhome for the last 15 years and 85,000 miles.
The base plate is where the tow bar attaches to the Jeep, using a modified Roadmaster towing baseplate, from my old Dodge Dakota.
The baseplate is a strong place to attach recovery hooks, when not towing.
It also forms the foundation for the hidden winch.
https://www.flickr.com/photos/lwade/...57603323570942
https://www.flickr.com/photos/lwade/...57604557867782
Old December 5th, 2017, 10:54
NAXJA Member #1145
Thanks for the reply. I've been wanting something like this on the front of my rigs but didn't know how to hide it away. I think I just found the first father/son welding project for my 17 year old when he starts welding class next year.
Old December 11th, 2017, 07:03
Dest's Avatar
Do leaf spring sliders give a better ride then relocation brackets?
Thanks for all the suggestions so far. In the spring I'll swap to some type of long arm kit and different shocks...
Rock Monster Beadlocks + TrxUS 33"x12.5" (Self-Install and Street Legal) 330LICIOUS Sierra Chapter For Sale 13 July 7th, 2013 02:00
'87 Comanche "Street Truck" Edition? IXNAYXJ Jeep Comanche MJ (1985 - 1992) 54 September 22nd, 2012 18:54
P.S. M&G A.K.A. "Curts curiously comfortable compact camp crapper." \\'anderer SoCal Chapter 14 August 25th, 2008 10:14
"Army makes soldiers get comfortable carrying weapons". . . actual headline. SBrad001 Non-Tech / Off Topic 18 August 28th, 2006 20:06
Is it possible to add list of users on ALL forums to primary "NAXJA Forums" page? XJ_MAC User Support, Questions and Suggestions 0 April 2nd, 2003 07:57
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
