Old December 4th, 2017, 16:56
XJ_NorCal XJ_NorCal is offline
Center Inlet/ Center Outlet muffler fitment
So I bought a Borla XR-1 (40942) muffler with the following specs:
2.5 in. Inlet - Centered
2.5 in. Outlet - Centered
16 in. x 4.5 in. x 7.88 in. Case Size
https://www.4wheelparts.com/Performa...&t_pn=BOR40942
It looks like I might have effed up because it appears the outlet should be offset according to the diagrams I've looked at. Can the muffler still be installed on my rig? If so, can it be done in my driveway (like I was hoping with the help of youtube vids) or should I take it to a muffler shop? I'm also worried about clearance issues as I still have a 4.5" lift and a ZJ gas tank skid plate to install. Any help is appreciated!
1998 Jeep Cherokee Sport
113K miles
I6 4.0 litre
AW4
NP231 Transfer Case
Old December 4th, 2017, 19:02
lawagoneer lawagoneer is offline
Re: Center Inlet/ Center Outlet muffler fitment
If you want it bad enough anything is possible. The easiest would be to exchange the muffler for the correct one. If not a couple of bends, a welder and a saw and it will fit. Can you do it in your driveway? Depends on your skill level and insanity. When I was young I did a lot of things to my race cars and hotrod that "couldn't be dine" simply because I didn't know it couldn't be done so I did it. Didn't always come out well and often wasn't the best way but damnit I did it.
Old December 4th, 2017, 19:10
I can't exchange. It was a private party sale. I checked quadratec and 4wheelparts prior to purchasing and they both considered it a "fit".
I guess I'll have to take it to a muffler shop. Hope it's not too bad.
Old December 4th, 2017, 23:31
Really shouldn't be too bad, a couple of bends to line up and a weld or two and you should be fine. Without seeing the muffler and tailpipe it's hard to say for sure but I can think of a couple of ways off the top of my head to line things up.
Center console fitment Reddout Midwest Chapter 6 February 13th, 2017 03:48
Exhaust leak at muffler inlet, outlet HappyDog OEM Tech Discussion 1 May 3rd, 2013 09:10
Muffler inlet goes into cat outlet correct? 995speed Modified Tech Discussion 23 June 11th, 2012 20:06
Another Heater Core ? Inlet and Outlet? Redsnake OEM Tech Discussion 1 February 21st, 2011 12:00
Catalytic Converter Inlet/Outlet reson46 OEM Tech Discussion 0 December 30th, 2003 12:59
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
