Old December 4th, 2017, 12:54
anthrax323 anthrax323 is offline
2001 XJ stroker build: keep 0331 head?
My 2001 XJ made it 240,000 miles before breaking a piston skirt. I can say with 99.999% confidence this is the original 0331 head (non-TUPY), as I've owned it since ~110,000 miles. Never had a single issue with it.
Given that it made it this far, is it reasonably safe to assume that I have one of the good 0331 heads? Or should I plan on locating a TUPY or other aftermarket head as part of the build?
Old December 4th, 2017, 14:17
tech1001 tech1001 is offline
Re: 2001 XJ stroker build: keep 0331 head?
If your building a stroker you want more power , I would look at a performance head to add to the power . the stock head is not good for performance even if you do a PNP on the head , the after market head was made to flow better to start with .
Old December 4th, 2017, 14:37
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
I'd swap it. No sense in building the rest of the engine and having to worry about possible head issue.
Old December 5th, 2017, 10:13
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Check with Russ Pottenger, he can do wonders with a 4.0 head, no matter if it is a 7120, 0630 or a crack free 0331.
He recently supplied forum member RCP Phx with a built 0331 head, along with a stroker kit.
Read about it here. It's quite powerful.
http://www.naxja.org/forum/showpost....&postcount=108
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old December 5th, 2017, 10:19
RCP Phx RCP Phx is offline
I sent Russ a new CCH 0331 head that's supposedly like a TUPY head.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old December 17th, 2017, 15:00
Did you ever decide what head you were going to use ?
Old December 18th, 2017, 22:37
Not yet - Clegg is offering me a 17k mile TUPY head off a customer rig for $380 shipped (surfaced and cleaned up), which is hard to turn down... but the tiny-ass 0331 exhaust ports are making me think more about it. Apparently the performance head sold by Titan and a few others (around $700) is actually pretty damn solid and breathes a hell of a lot better. That's what I'm leaning toward at this point.
The 232 crank arrives on Wednesday (decided to build a ~4.2 mini-stroker), and the pistons by the end of the week, so I need to decide soon.
Old December 19th, 2017, 15:34
Another question: should my connecting rods be re-usable even after 240,000 miles? Being a mini-stroker, the geometry will only be slightly off from stock (~0.100" longer stroke).
Old December 19th, 2017, 17:13
Not without rebuilding, do the pistons account for the stroke?
Old December 20th, 2017, 13:28
Nah, I'll be using a crankshaft out of an AMC 232 (3.500" stroke instead of 3.400" stroke). Stock 4.0 rods, bored .040" over, Silvolite 2229 pistons.
The block is at the machinist as of yesterday being hot tanked, bored, and having the mains inspected to see if it needs line boring.
When you say "not without rebuilding", do you mean replacing the studs? Rod bearings will be brand new as part of the build, as will wrist pins. Do the 4.0 rods have wrist pin sleeves/bushings? I'm guessing that since they're press-fit, that's a negatory.
Old December 20th, 2017, 13:33
Stock rods are press fit, but the rod gets re-sized at the big end and anything else when rebuilt. Good rods/pistons like from Russ are machined with a bushing as a "free-floating" pin.
Old December 20th, 2017, 13:52
Why resized? You mean as a result of use for 240,000 miles? I can't just toss new rod bearings in?
Old December 20th, 2017, 16:45
Nope, the big end usually elongates!
Help me identify this head. I have a 2000 xj with a blown 0331 head. A guy on line sa JeepNovice63 OEM Tech Discussion 11 June 12th, 2017 01:20
Renix head in stroker build PacificEd Jeep Street and Performance 8 February 3rd, 2015 05:02
I need a head (non-0331) in SD 01_XJ SoCal Chapter 3 July 23rd, 2010 15:51
0331 HEAD tugalo OEM Tech Discussion 6 July 22nd, 2010 22:04
question switching from 0331 xj head to 0630 tj head jonnyz123 Modified Tech Discussion 2 May 15th, 2009 20:11
