Old November 15th, 2017, 07:06
sm465np205 sm465np205 is offline
5.3 swap
Couple pics of the shit box itself. Home made bumpers, full unibody stiffeners, 100% new custom floor pans, Dakota bastard pack rear, front stock coil ACOS, iron man short arms, Durango box ZJ tie rod, 231 SYE with a Novak cable shifter, ARB on board air, crappy 27 spline 8.25 with a limited slip and open hp30. Fun little mild built Jeep
Sent from my XT1565 using Tapatalk
Old November 15th, 2017, 12:48
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Re: 5.3 swap
This thing is sick biscuits. Good job dude.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old November 15th, 2017, 21:54
TRCM's Avatar
TRCM TRCM is offline
Re: 5.3 swap
I'm about fed up with the trans in mine.....if it needs much more money to fix (rebuild 2 yrs & 9k miles ago, and now it's doing the same thing again, plus the torque converter appears to have crapped out).I['ll be going to a V8 as well.
Already located a LS 6.0, 4L80E, and NP231 with all wiring & computers to use as a donor
Old November 16th, 2017, 06:06
Vintage Smoke Vintage Smoke is offline
Re: 5.3 swap
I dont think the NP231 ever came behind the 6.0/4l80E unless someone converted it. In that case you may want to consider an upgrade to a stronger case. At the very least beefing up the 231.
Old November 16th, 2017, 06:39
indian's Avatar
indian indian is offline
Re: 5.3 swap
the GM transfer cases use 6 bolt pattern but it is not the same pattern like Jeep TC. You just need a adapter and other input shaft to match the Jeep TC to GM trans. I and some guys from here use the NP231J behind 4L60E without problems.
I would suggest beefing the NP231 (6 planetery gears, thicker chain) or use the GM NP231C (has already thicker chainh..) or NV241 TC.
I switched the input shaft from NV246 (originaly behind 4L60) and the planetary set
Old November 16th, 2017, 07:32
Re: 5.3 swap
Its not what trans its behind....its the 6.0 which is a seriously torquey motor. Driven cautiously the 231 will be fine. With the upgraded planetary, chain, etc, it will be better, but in my opinion whats the sense of going big on the motor if every time you hammer down you are worried about the weak link which is the transfer case. Axles can always be upgraded later as money allows or if you break them without disturbing the rest of the drivetrain, but since the transfer case requires custom adapters, mounts, cross members, upgraded parts, shift linkages, etc to install why not start with a stronger case the first time and do it once? Again...just my opinion. Everyone's needs, budget, expectations, etc will vary.
Old November 16th, 2017, 07:38
5.3 swap
I think they're tougher than some give them credit for. I've seen a few 231 failures but it was always a result from an impact from a rock or stump or the like. I rebuilt mine but never upgraded the planetaries or chain I guess I'll see how long it holds up. Ultimately I'd like to run a flipped 300
Old November 16th, 2017, 09:45
clydefrog's Avatar
clydefrog clydefrog is offline
Re: 5.3 swap
23k miles on mine mated to my 5.3 with 4l60e. Zero issues, only running 3 planetary gears. I am pretty, actually extremely rough on it. WOT on accel pretty much anytime I can. I do have a slip eliminator kit on it, thats pretty much it.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old November 16th, 2017, 21:52
TRCM's Avatar
Re: 5.3 swap
it's the chevy version....so NP231C
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 08:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
