Old September 18th, 2017, 22:46
indian's Avatar
indian indian is offline
Re: XJ LM7 5.3 swap
Originally Posted by Vintage Smoke View Post
Google "The Story of Goldilocks and the Three Bears" LOL!!!
Sorry...couldn't resist!! In all seriousness that is fantastic work!!!
hahaha, You are right!
thanks
Old October 3rd, 2017, 11:18
indian's Avatar
Re: XJ LM7 5.3 swap
WJ brakes and steering swap almost done. I still have to change the pitman arm for a flat one from TJ to have track bar joints and drag link joints parallel. Had to shorten the drag link and tie rod about 8 cm (3") to match the length of the XJ dana 30.
Old October 3rd, 2017, 11:22
indian's Avatar
Re: XJ LM7 5.3 swap
some mud driving...
Old October 29th, 2017, 14:36
indian's Avatar
Re: XJ LM7 5.3 swap
https://youtu.be/zIsHSQqUCsA
Old October 29th, 2017, 14:40
racer32's Avatar
racer32 racer32 is offline
Re: XJ LM7 5.3 swap
Haha Nice!! Congratulations
Old October 31st, 2017, 07:59
burntkat burntkat is offline
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Great build! I love the sound, what are you using for the muffler?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 31st, 2017, 08:42
indian's Avatar
Re: XJ LM7 5.3 swap
I recently switched back to flowmaster delta 50 series, because with the dynomax turbomuffler I missed the V8 pulsing sound.
Now I am very happy with this setup.
WJ brakes and steering work great. Leaking from the rear engine cover is solved. The PCM tuning is almost perfect - the consumption shrinks from 11 mpg to 18 mpg and the PE mode is working accurately.
I think the next bigger update will be the NV3500 manual swap
Old October 31st, 2017, 15:35
NAXJA Member #1145
Re: XJ LM7 5.3 swap
Crap. That's the muffler I just bought. I don't care for the drone and overall loudness of the Flowmasters.
Old November 1st, 2017, 06:08
indian's Avatar
Re: XJ LM7 5.3 swap
the delta 50 series has not drone inside (in my setup) and from outside has a very nice sound
https://youtu.be/oGB44BXCI5U
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
231 swap into a 89 xj with aw4 bcmaxx Modified Tech Discussion 6 October 17th, 2007 15:31
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
