Old July 19th, 2017, 12:14
trippled trippled is offline
Re: hjeepxj's build thread
Looking good! Can't go wrong with the silver and black
Old July 19th, 2017, 17:05
hjeepxj's Avatar
hjeepxj hjeepxj is offline
Thanks brotha! Hoping to get it out this season!!!
You coming to COfest?
2000 XJ 5.5" Lift w/Deavers and TNT arms, 30 front w/Super 30 kit, ARB, truss, etc. 44 rear w/35 spline alloys, ARB, Wilwood discs, truss, etc. Hooligan stiffeners front to rear, Hooligan fenders, Trailready front bumper, JCR rear bumper w/tire carrier. *under construction*
Old July 20th, 2017, 12:14
I wish,but it's not gonna happen. Should make the spring Creek trip if you're planning on going.
Old July 20th, 2017, 20:06
hjeepxj's Avatar
Bummer about COfest.
I *should* be able to have mine ready to go by Spring Creek. Wish me luck!
Old August 9th, 2017, 20:37
hjeepxj's Avatar
Got the rear bumper on after replacing the nut strip from JCR that broke. Everything but the UCA's and brake lines are hooked up in the front, just need to bolt that stuff up. I cut the old metal sleeve out of the drivers side UCA bushing as it was junk not realizing that the new bushing needs it so that's on order.
Stuff left to do: UCA bushings, UCA's, final mount TNT xmember, hack n' tap SYE along with rear drive shaft, hook brakes up f/r, attempt to set alignment, mount shocks, plumb the ARB's, mount the rocks rails, and a couple other small odds and ends. It should be good to drive then. I do want to sand the interior, coat with top secret, install the cage, dynamat the rear and reinstall the interior but if I can get it drive-able I'm going to wheel it.
Old August 10th, 2017, 12:34
ay ay ron ay ay ron is offline
Beautiful build
Old August 11th, 2017, 10:22
hjeepxj's Avatar
Originally Posted by ay ay ron View Post
Beautiful build
Thank you!
...sorry...another build thread... blondejoncherokee Sierra Chapter 1501 June 30th, 2015 16:07
hjeepxj's "Build" Thread hjeepxj Modified Tech Discussion 10 May 7th, 2014 19:17
New to the thread/ New build kybray44 Sierra Chapter 5 March 8th, 2010 23:04
my build thread shawnxj Red River Chapter 4 May 10th, 2009 09:28
Attn:hjeepxj freerider15 Colorado Chapter 3 October 15th, 2007 22:44
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
