Old March 2nd, 2012, 14:31
hillclimber hillclimber is offline
Question Code Question
What code, or codes would you expect to see on a 98 XJ, 5speed, 4.0 if the cat were plugged??
Old March 2nd, 2012, 16:18
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
Re: Code Question
Best for you to describe your symptoms and any codes you see, rather than to be "hypothetical"....
Old March 2nd, 2012, 17:33
Re: Code Question
Well, it's lacking power in the last week or so. Mostly around 1,600rpm. CEL just came on today.
I don't hear any hissing, but there is a bogging noise around the intake/airbox area when you try to accelerate under load @ about 1600 and higher. The converter is a little noisy (rattle). Changed the plugs/wires, and the plugs altough old, looked clean and dry. The motor runs great, burns no oil, and has 45-50lbs of oil pressure.
Ordered a tester today, and I should have it in the morning. I have no problem replacing the Cat, but I'll be laying in the snow covered driveway to do it, and at $175, I just want to make sure.
Old March 2nd, 2012, 19:39
Reverend Jim's Avatar
Reverend Jim Reverend Jim is offline
Re: Code Question
P0420 is for "low efficiency catalyst" on your '98.
Old March 3rd, 2012, 04:02
Re: Code Question
Yup, gotta get those codes. They are absolutely the key to resolving this. Post the code or codes when you get them and go from there.
Old March 3rd, 2012, 06:05
Re: Code Question
And the code is........PO420.
Just as I thought. Thanks for the help guys.
Now, during a storm, I just have to change out the Cat and Muffler. AARRRGHhhh
Old March 3rd, 2012, 09:36
Re: Code Question
Changed both the cat and muffler, and it seems better. I only drove it a few miles but my acceleration seems to be back. Hard to tell with snowcovered roads. The old cat was JUNK. Looked ok on the outside, but the inside was pooched.
Old March 3rd, 2012, 10:23
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Code Question
You may still have a problem. A broken (rattle), pouched CAT is usually caused by the engine running too rich. IF you recently fixed a rich running problem, then you may be OK now, other wise if it is running rich it may cook and break the new CAT pretty quickly. I would get an volt meter and check the front O2 sensor readings while the engine is running.
http://www.naxja.org/forum/showthrea...+test&pag e=7
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old March 4th, 2012, 05:29
Re: Code Question
To be honest, the cat has been doing the death rattle for almost a year, yeah I know sad... I don't think it's running rich. The old plugs looked like it may have been running lean if anything. I can check the upstream o2 sensor. I'm no stranger to multi-meters, and I'm not mechanicly challenged or anything. It's just that I'm more used to dual point distributors, 4 barrel carbs, and all that stuff....Hello, my name is hillcilmber and I am old..
Old March 4th, 2012, 09:15
Ecomike's Avatar
NAXJA# 2091
Re: Code Question
Yep, some of us cut our first teeth on carbs, points, etc, LOL! My first intro to Electronic fuel injection was my 87 Renix Wagoneer when I bought it around 2006. It eventually replaced my 73 Ford LTD, 351 V-8 with a 2 barrel....which still only had 87,000 miles on it when I finally sold it in 2007-8?
code 13 question buster cherry OEM Tech Discussion 1 February 1st, 2010 10:40
Code question FlexdXJ OEM Tech Discussion 3 October 26th, 2009 17:17
E-Code Question Cherokeekid88 Modified Tech Discussion 5 January 28th, 2009 19:07
98xj 4.0L high idle question code question rapom OEM Tech Discussion 4 June 27th, 2005 16:18
code question? HilltopXJ OEM Tech Discussion 4 May 26th, 2005 21:46
