Ironmanandy
- North Carlolina
From all of the abuse our XJs can see offroad, it is important to keep your driveline planted. The factory block brackets are the main weak point and worn out motor mounts can allow your motor to shift. Nobody wants their fan getting fancy with their radiator or their brackets to give out after a hard hit.
Our Motor Mounts are made from 1/4" high-tensile 100,000 psi laser-cut and CNC-formed steel plate for unmatched strength to replace the constant failing factory motor mounts. We use Clevite style 1 piece rubber bushings. Steel is guaranteed for life. Ironman exclusive CNC machined DOM tapered bushing sleeves.
The XJ motor mount brackets are 3/16" thick grabbing 7 and 8 holes as opposed to the weak 3-bolt mounts. Two parts formed per unit instead of competitor's 6-7. Allowing for less weld deformation and edge weaknesses. These are designed to withstand high horsepower and racing applications, but great for on and offroad applications on all levels. You won't ever have to worry about your mounts again!
4.0 Motor Mounts - $130
4.0 Motor Mount Brackets - $230
4.0 Motor Mount Kit - $340
Members get 10% off - PM For Details
https://www.ironman4x4fab.com/xj-motor-mounts
If XJ isn't your thing, we have motor mounts and transmission mounts for ZJs and WJs as well.
