ericfx1984
- Kansas City Area
this is not my original thought but rather a collection of research I have done online...
Parts needed
front coils
89-97 T-bird/Cougar springs V6 or V8, either will work... but the v8 is a little stiff (cost around $20 or less at the bone yard...
notes: you will need to make a coil adapter or mod the coil bucket top from the donor T-bird
http://www.naxja.org/forum/showthread.php?t=68842
rear lift...
there are a few cheap options for this...
option 1 (the cheapest) : S10 bastard pack
pros: CHEAP!
cons: could be a little more flexy, can be a little rough, but not too bad
cost: around $30 for donor leafs, up to $60 for hardware (u bolts, center pin, spring clamps)
Option 2 (flexy beast): XJ/XJ bastard pack, with autozone $30 shackle
notes: similar to the S10 bastard pack but not as much lift in the spring, and has a longer shackle, as a result it will FLEX like mad!
cost: $30 more than the s10 bastard pack
http://www.cherokeeforum.com/f51/s10-springs-bastard-pack-1380/
http://www.autozone.com/autozone/ac...&fromString=search&itemIdentifier=204654_0_0_
NOTES: your leaf springs and shackle bolts should be tightened with your Jeep on the ground! and should only be torqued to around 65 ft/lbs
Shocks:
Jeep JK Rubicon shocks
cost: free-$50 take off
these are good for 2"-5" maybe more with extensions or bar pin eliminators
now you need to worry about tuning the front end
problem 1 your caster is WAY OFF!!!
this is fixed by shimming the lower control arms... shims can be made from metal and can be stacked... they can also be found in XJs in the bone yard
however, stock arms will limit your front axle down travel, as a result you might want to clearance the axle side lower control arm mount, or get a set of after market lower control arms...
NOTE: a better option would be new lower control arms that are adjustable, or at the very least lengthened, cost can very... expect to pay around $130 for a set of fixed control arms for 3-4 lift
cheap option for control arms are WJ rear LCA... they are tough and can be modded to different lengths with very little work
Problem 2: front axle shift
easy fix... and if you lifted your Jeep then you do have it...
http://go.jeep-xj.info/HowtoTrackbar.htm
Problem 3: Alignment
easy to do at home
http://go.jeep-xj.info/HowtoAlignment.htm
you might have some rear drive line vibes... if so you need to shim the rear axle and install a transfer case drop...
http://go.jeep-xj.info/HowtoTCdrop.htm
you will also need longer brake lines: brake lines from 95 yj (front) 96 dakota (rear)
Parts needed
front coils
rear lift...
pros: CHEAP!
Shocks:
easy to do at home
