Ex Jay
- Philips Ranch
if i search anymore my eyes are gonna bleed...
1993 4.0 piece o crap.
Rear wiper/washer works fine.
Front wiper works fine including delay.
Washer mostly doesnt.
Assumed since day one that front pump was bad.
Relocated and switched to renix era bottle.
Tested, both pumps work great.
Pushed washer tab forward on multifunction switch and pump began to spray but almost instantly began to slow. then stopped.
Now when you push washer tab nothing happens. If you keep pressing it over and over it will eventually cycle the wipers as youd expect but never engage the pump.
checked fuses
re-tested pump
hose is clear
tried bypassing intermittent module with no change
so what the heck!
Ive never seen a multifunction switch fail this way but maybe?
Horrible luck finding a washer circuit diagram.
Any help would be appreciated.
checked fuses
re-tested pump
hose is clear
so what the heck!
