coldoath
- West Texas
Easy enough - have the header split 1/2/3 and 4/5/6, have an exit flange/collector (three-into-one) for each set, then run parallel tubes and cats/mufflers out the back.
Awful lot of work for minimal gain, tho. Better off fabbing up a properl equal-length header with two three-into-one collectors dumping into a wye collector, fixing the downpipe to match, then leaving well enough alone on the rest (2.25"-2.50" is about right for the typical 242ci. A mild stroker will want 2.75"-3.00" exhaust.)
Yea I figured that you could do it with a custom job. Lol you can do anything with enough money. Just haven't seen people run duals regularly. Thx!
