- Southern Maryland
I've been working on a project and the last item on the list is giving me fits. Basically I have two pieces of soft rubber that will seal an opening from both sides. I need to glue those pieces together then warble it into the hole so the new single piece will seal both sides.
I've tried contact cement, rubber cement, 3M gasket adhesive, gorilla glue, and they all separate from the rubber as soon as I twist the seal to push it into the hole.
I'm about ready to drill some holes and use pop rivets around the rubber as a permanent clamp but figured I would ask here if anybody knows of something super powerful for rubber that will permanently bond two pieces together and doesn't require a waiver from the EPA.
