DeathValleyPaul
- Los Angeles Area
Warn Industries Snatch Block #61560
19,000 lb rating, has grease port and will double the pulling power of any winch. If you winch, you should also have a snatch block. You can never have too much capacity. Picture yourself pulling the entire dead weight of your XJ straight up an embankment with an 8000 lb. winch. Using it reduces your amp draw and keeps your winch motor and drum much cooler. Use the snatchblock with a strap around a tree or rock to allow you to make your winch cable turn a corner without fraying it, or melting a synthetic cable. It cuts the load in half.
New sells for $90 to $96.
I have two, and I am keeping one. This one got a little scuffed riding around in the tool box but never got used. An absolute must for recovery, or hoisting a big load. It is also very useful for making your winch rope make 90 degree turns without the cable scuffing rocks etc.
$62.00 shipped. Price is firm. Paypal is ok.
