TRAILREADYXJ
- Raleigh NC
Since my XJ will go one of two directions, I have decided to sell some parts off it. I am either going to,
A: Turn it into a chopped trail rig on one ton axles with V8 power (current engine and trans are going into the MJ).
OR
B: Part it all out to help fund the MJ build.
Although the first would obviously be the coolest, the lack of time and money will probably lead to the 2nd. Although I hate to see her go, she has seen better days, and served me well.
Therefore, if you need ANY parts for a 1990 4DR XJ, just ask, even if it's not listed below. Please note, all lift parts have been transferred to the MJ. I may sell my rear spring setup, but it has to stay for a while.
Parts currently available, contact me for a shipping quote. This also includes some other parts I have, not from the XJ.
-HP D30 Front axle, Vacuum disconnect modified with cable (like posi-lock). 3.55 gears. Needs pass side axle u-joint, maybe the whole shaft, and possibly hub bearings in the near future. Good upgrade for 00-01 with the low pinion D30 (can use your old unit bearings and brakes if needed). $75 (still need to pull, but is loose under the Jeep.)
-AW4 trans, 21 spline. $50 obo
-84-96 XJ Taillight, RH, Good condition, $25
-8.8, 3.73 ring and pinion, used, ford brand. Make offer.
-8.8 31 spline Factory LSD, The centering pin hole is stripped and needs to be repaired, but should be usable. Otherwise in good condition. $50 obo
-Stock T-case Skid, no hardware included, $15
-Stock Gas tank skid, no hardware included, $30
More to come! Trades considered!
These items are also for sale locally. I am located in Snowville VA, about 30 min from Blacksburg toward Claytor Lake. I prefer local pickup or delivery, but can ship most items if need be.
OR
