I am thinking of the best location for hood vents .
I purchased aluminum louver panels from synergy suspension with the following dimensions:
- long ones: 15.375" L x 4.0" W
- the square short ones: 7.71" L x 7.96" W
My objectives are:
1- to create the best possible heat dissipation for the ridiculous under hood temp. using the long vents. The theory i know is that hot air is lighter than cold air so it should always flow out of the vents.
2- to use one of the square vents as a functional cold/ambient air intake for my AEM intake setup. What i have in mind is to create an insulated enclosure around the filter using the same material used for hood insulation and to have the vent directly above the filter as much as possible. This way The filter can easily suck air at ambient temp
So please tell me what you think of this preliminary locations in the picture using template paper. Those location clear the hood support panels.
Would this setup " functionally " work ? which direction should the louvers face , i am thinking the curved slots should face the windshield instead of facing the incoming air rush.
My objectives are:
