1988MJeliminator
- Humboldt county
Hello,
I have a 1988 eliminator 2wd and I just recently put on 3.5" lift and right after installation I have noticed a loud clunk under the driver and passenger floor boards.
All the parts I used:
Rubicon express 3.5" front coils
JKS UCA
JKS LCA
JKS adjustable Track-bar
JKS adjustable sway bar links
Bilstien 5100
Right after finishing putting the lift on I drove it around the block and discovered a new loud clunk that I can feel under my feet while I drive. I checked everything for movement or rubbing and the only thing that I found that seems to have play is where the LCA meet the unibody frame. I re-checked the torque specs for what the bolt should be tightened on the LCA but all my bolts were all torqued. The clunk is really loud when going over little bumps in the road but its goes away when your on the freeway. there are still minor clunk noise on the freeway but you can't really notice it. Also when I brake over little bumps the clunk goes away.
I was just wondering if anyone has had this problem before or if anyone has advise that will help me solve this irritating clunk. The truck is used as my DD and I have learned to live with it but it is definitely annoying when your on a really bumpy road.
Thanks.
JKS UCA
JKS LCA
Bilstien 5100
Thanks.
