SOMEONE Jump on these!!! Deaver springs
spring under on an XJ?
Yeah, Most leaf sprung desert rigs, with the exception Jeepspeed run spring under. It allows a softer spring rate to get more travel and helps to eliminate axle wrap with the bigger travel. All the force from torque is spread out to the main leaf directly, rather than on the smallest leaves that will splay open until it gets to the main leaf.
Hope that makes sense...
-Dan
-Dan
i knew about the spring under stuff, just never heard of it done to an XJ.
