Have a 1-Ton Steering Setup from Rugged Ridge for my XJ and was thinking of upgrading my rod ends to the HEIM Spherical Rod Ends. Anyone have input on what I should do?
IIRC, the RR steering has one of those oddball TRE's on the passenger side. So no, swapping heims will not work with that setup. The links are too short.
Buy ruffstuff or other steering kit, if you want to run heims. Or, buy the joints and some tube and have someone local build it for you if you cannot do it yourself.
I don't think heims are an upgrade over 1 ton tie rod ends. I run heims on the xj as I don't have a reamer so it was cheaper/ easier than going to 1 ton tre's. Building the steering on the wj after the Dana 60 swap, I'm sticking with 1 ton tre's.
