- NJ, U.S.A.
Vehicle: 92XJ 4.0
I am in the process of replacing fan clutch (also shroud), and have run into a bit of a tight spot - literally.
I was able to get the fan out by way of my old (broken) shroud and using a screwdriver as a level to rotate the pulley, but I'm stumped on getting it back together:
I was only barely able to get my hands in far enough to reinstall 3 nuts with the shroud out of the engine, but I just can't get to that fourth one. Worse, I can't rotate the pulley now - it fell off while I had things fully apart, and while I've been able to slip the pulley back on and the belt back over it, I can no longer "slip it" under the belt.
So, why don't I loosen the belt a bit? I'm trying to, but don't have a wrench long enough to reach that lower nut on the back of the PS pump. Going to swing by the local Home Depot later and see if I can get a longer 1/2", but am open to "DIY solutions" as well.
I'm really hoping I don't have to go shaving down the bottom of my brand-new shroud to get it in without pulling the whole fan out again, because I just can't figure out how to get my hands far enough in to put nuts on the studs with the shroud in place.
Is there some sort of secret trick that I'm missing here?
